mountainguyed67
Here’s a 6-71, seems to be the same procedure.
You are welcome to try that but I would not stand too close to it when starting.
Nothing against the guy making those videos but when he was taking the "things" off the top of the valves and did not know they were called "Valve Bridges" it makes me question how much he really knows.Here’s a 6-71, seems to be the same procedure.
I mean if the bad guys were coming fast over the hill and the only way to get out of the trouble I might but not on a machine I had money invested in or a real need to see it run for more than a few minutes.
Next time it decided to stick it could be at full throttle and you might only have a few seconds to get clear before parts start flying. Especially as your engine has the two screw levers on the control tube that means one injector stuck at full fuel means all are stuck at full fuel!
you used to be able to buy the timing pins individually-they weren't that expensive, maybe they are now.
Before you pull the injector You could measure the injector height with the valves down
So you would know what height yours are set at.For what purpose?
Is there a tag on the side of the valve cover? Detroit was good about giving you all the special option information there if some one had not removed it!There’s a tag with serial number on the side, I forget if there’s anything else on it.
