Asa Joel Spicer
Hey guys, I bought this 2005 volvo ec35 about a year agoEverything functions flawlessly... boom/bucket/swivel/plow all work great... until you go to turn.
Driving straight, high and low speeds both work. As soon as I let go of one of the levers even a bit, i lose all momentum.
If I try to turn with one stick forward and one stick back, usually only one track turns and it's very slow. Seemed to be the right track was the worst for this but now seems the left is getting slower also.
If I live the machine with the boom and swing with only one track it usually turns very quickly.
If I'm traveling I can use any boom or blade controls fine, doesnt seem that I've lost any power in those.
Motor does not seem to bog either. Maintains rpm during the steering maneuvers.
Once oil is warm, I can only turn in low gear. If it's in rabbit and I try to turn, both tracks quit. If I switch to low they start moving
Any help or pointers would be great!
I'm wondering if the valve body that the levers go into may be bad? Other than the pump isnt that the only thing both tracks share?
