buckfever
Are you sure it's the hinges that are locking up and not the lift cylinder over extending?
I don't intend on starting an argument but in my opinion based on the pictures there is nothing I would worry about there, with a heavy (probably spring) suspension with short sides and relatively short bed I wouldn't be worried about flipping it because of the pins, most all of my trucks have more wear than that, I've had several new beds installed and pins aren't tight tolerance like heavy iron. So in short sorry to disagree with everyone but I don't think you have a issue unless you guys are seeing something more in the pictures than I am ?
Pj
I looked again, I'm sorry I just don't see a problem, I see wear but I don't see spending money on something no worse than that on a $1k truck or a even a 20k rig.
If you get a truck setup right they don't tip as easy as everyone let's on they do
Pj
That truck is just a crosswind from going over. I don't want to kill anybody .
More than scrap unless it weighs more than 25,000lbs. But still a great price! We don't get much for metal here, 70-80$ a ton. Some years back had to PAY to get rid of metal.
Yair . . . Dunno, but I wouldn't think those hinges would be all that inclined to stick. (he grins) More likely hydraulic as mentioned by buckfever
I've not had much to do with tipper/dump trucks but I have built and fitted a couple of bodies and you folks tell me the greasable bushed pivots and the guides and tapered pin locators were a waste of time?
Cheers
I have been around several dumps that acted like they were sticking when they were all the way up. I dont think it is the best thing to do puting it all the way up. Not to belittlie you but is this your first dump truck? They are a little scary and most will move around some with the bed up. This looks to be a good truck i think you made a great buy. I think your hinges are good to go but i would greese them up.
... between the two of us we'd know everything.... you know every thing but.....
It could be the ram sticking some it seem to have air in it and i can never get it all out.
This is my 3rd dump truck first one that I did not convert and was a factory made one. The truck is really in good shape other than need cosmetic tlc I hauled a 100 or so loads this fall with it. The pins are really worse than it looks and I have the bed off and upside down in the shop seems like the right time to fix it. It could be the ram sticking some it seem to have air in it and i can never get it all out.
You really should have hooked the chain into the receiver on the drivers side... really.
A motel6 one time, just wasn't quite enough...
OCR... lol
Happy New Year, everyone... :lmao
Maybe my viewing of it was better than everybody else's :beatsme But I could see at least a quarter inch of wide open space in there. When its all said and done please report back to us how much better that truck is to spread with.![]()
I just see the mounts for the pins that look a little egg shaped, hard to tell how off it is without a pin in there.
Rmk4x4, that truck seems familiar, are you on the Alaska 4x4 web board?
