Hose to drive motor burst so had to remove panel. When I did, I saw no motor, no hoses. Just dry compacted dirt.
Somewhat stunned because this was all new to me -- the digger, Takeuchi TB016 was 5 y.o.
Cleaned it out and thought the innards were awfully rusty.
I thought this was a(nother) design fault -- I know the motors are horribly expensive yet they have no protection from dust and water. Just a metal panel held on by just three bolts.
Got an old tractor tyre inner tube thinking I'd make an oversize gasket, leaving the rubber flopping outside. Then there's the openings where the hoses pass through -- why are there no gaiters, a bit like a CV boot.
But on reflection I thought that rather it being a brilliant idea it was more barmy. Because if water were able to get in where the hoses go in -- because no way could the gaiters be made perfect -- , it wouldn't be able to get out, making things even worse than ever.
It's the same with the 'belly panel's I'm calling them: What a mess under there where you're trying to replace a hose.
So I got a pistol attachment for a pressure washer to be able to shoot upwards. I'm dubious about making those panels watertight, too. Ideas?
Get a cheapo sandblast kit and repaint the motor and housing?
Anyone have experience of this? Or reflections?
Thank you.
Thank you.
