Excellent!
Get Issac, IC weld, on you tube, best man with a torch I have ever seenTorch if you're decent with one.
Dunno, have done it on logging equipment without issues.Torching holes larger, and a requirement for tight-fitting bolt shanks are not two compatible moves, IMO.
We're talking about taking out 1/16" of metal, accurately, all round the holes.
Slightly oversize bolt holes in track shoes, means you will never be able to keep the track shoe bolts tight.
There's action happening on the Norseman drills - factory advises they've been shipped to my helpful HEF assistance man. He says he'll likely have them Friday 24th Nov., and they'll be on their way to me shortly after. I would hope they arrive by mid-December.
They are adapt at getting by, Maybe where the old adage 'I've been doing so much for so long with so little, I'm now expected to do absolutely everything with nothing' came from.Yea I dunno why OzDozer does not just channel the skills of the Pakastani Truck Repairers.
To fix anything you only need an angle grinder, transformer stick welder and oxy.
The way with just a single welder and angle grinder they rebuilt the splines that the sprocket presses onto on the final drive hub of that D8K was just amazing.
Put in its most simple terms. Some people have standards, others don’t.
I especially like how they gather around out in the front yard in the dirt, around a pan of dirty fuel and reman those big diesel truck engines. It's always a pleasure if they take the crank shaft into the back room, weld on the bad journals and re-cut them on those antique (well worn in) laths. Makes me wish they had a shop closer to me.Yea I dunno why OzDozer does not just channel the skills of the Pakastani Truck Repairers.
It needs both, getting this wrong out in the way out outbackOil is a lubricant, water is a coolant. Needs cooling more than lubricating. Add washing soda to tap water to mostly eliminate rusting, does leave white powder. Those look to be what we call core drills. I'd probably start about 125-150 rpm.
