Got around to it this morning, and spent a good 4 hours just getting the big ends onto the crank! This engine has a good reputation but as far as this bit is concerned the only thing I'm prepared to call it is a "design atrocity". SHAME on Deutz.
The first attempt was the rear hole with the block on its side as this allows the rods to swing on the piston pins 'relatively' freely. I've seen some videos with the block on one of its ends and the rods can easily become difficult to manipulate. Got this first one done but the second rod in the next to rear hole quickly became a headache. I couldn't get the cap on strictly finger tight but all the way or almost. I kept getting into a situation where the last bit of screw tightening had to be done with a small ratchet even though still with a finger tight fit but ended up with some bindding and no free play. I went at it about ten times before gettin' totally fed up. Then it was "out with the *%$&#^ crank"!
Once the crank was hanging on the hoist I tried the same rod on the same journal and AGAIN it started giving me a hard time. After a few tries I took another rod and cap and that one wen on like butter. Finally got the remaing 4 done this way also but the problematic rod and cap continued giving me some difficulty. In the end they all went on OK and tested with little but free play and next to no radial clearance.
THE problem is hsitty design, and a crank that's like new in specs with new standard bearings. You cannot SEE the dowel remaining engaged while mating the cap and its bearing to the rod and its bearing, or any time after first approaching the crank with the cap and its bearing. Also the bearings are bent at a slightly wider radius which doesn't help in the already difficult assembly. The other engines, at least the ones I have done (Ford, Perkins, Cummins) with the punched lock at the bearing joint coinciding with the cap joint, are far superior in this respect. You 'pee' around blindly throughout a task that requires confirmation of POSITIVE dowel engagement until closed finger tight but you CANNOT provide this. It's like shooting at an enemy you last saw 30 seconds ago in the fog.
So there, remains to torque and recheck for play, reinstall the crank and torque, but I feel good about the job done. Otherwise I would have gone on never knowing if I had left a bearing jacked up on a dowel just like the last guy who did this engine. Made some videos, they'll be part of the build tutorial later.
