Hey all, I’ve got an old 690D LC that has a bad hydraulic leak at the final drive. I was hoping maybe someone here would have some experience with what’s going on. I read in the manual that it’s not necessary to drop the track to get the propel motor off but I’ve never messed with heavy equipment before so I’m not sure what I’m getting into. It streams out fluid even after you’ve shut the machine off. I took the inside cover off and the propel motor side is all dry, the leak is right at the sprocket… and it’s definitely hydraulic, you can’t even run it for more than 5 minutes without having to add fluid. thanks for any help
