BC Placer gold
We have replaced the negative & positive cables with heavy welding cable. New gear reduction starter. Modified for fit of group 31 battery….
After each of these changes will start perfectly (with high cranking speed) for a day or two…then no start without boost with a second group 31.
Very warm here today; barely started after 2 hour shutdown. If holding crank will barely turn over then speed up a lot (I believe due to the gear reduction starter) and start.
When tilting cab for starter replacement saw a negative cable from starter to frame…left it alone as figured starter well grounded to engine/frame. Did see some green corrosion…could this be the problem all along?
I (confess) bad at electrical! Have a basic meter here at camp…
As a side note our newly acquired Hitachi EX100-1 (1994) starts within 1/2 second down to -8c (lol!) did install two new group 31’s…
Could the trouble be hydraulic loading of engine? Have noticed a slight ‘twitch’ of boom occasionally when starting.
