I ended up finding a low hour pump off a 333g from a burned machine. The center section is different so I swapped mine to it. I was able to calibrate the machine and it’s working great now. Having issues with it overheating though, which was happening before, it’ll run for a while then get up to 220°, leave it running at full throttle and it’ll cool down to 205 pretty quick but as soon as I start working the machine it starts to run up again. Thermostat was replaced about 2 weeks ago, water pump is good and coolant is new. Cleaned the coolers real good but it’s doing it after running the machine an hour or 2
