redmack
By the time I'm done, we should have a text book with Deere excavator problems :Banghead
As most of you know, I just bought this machine about 3 months ago, my first excavator. I put it in about 25AC of stumps and that will tell all with any machine! There was one leaking cylinder on the boom that the original owner agreed to fix when I bought it and did so. After I got it home and worked it for about week or so the other boom and the top arm cylinder started leaking. I had them repacked by a local guy who is very good at it and the Deere dealer done the first one. Started back at it and after couple of days of work and noticed that they "all" had started leaking, even the one on the bucket that hasn't been touched. Of course the more I work it the worse it gets. No codes and had Deere mechanic check pressure etc. and found nothing wrong. He had to use his lap top to check codes because my cab monitor would only show dashes (------) and just didn't work when he tried to pull codes or anything else. Pulling oil sample today. My worse fear is the pump is coming apart and metal shavings are scaring the rods or eating the seals. Any ideas? Thanks in advance!
