D8T SU BLADE: LOOKING TO BUY
Jnocano
Texas
Greetings,
Does anyone here have any information on a used D8 SU Blade? Looking to spend around 20,000.
Would have to add tens of thousands of dollars to that price to get a D8t here in Canada. That may get you a 15,000h machine…..
He's only looking for an SU Blade, not a complete machine.........
To the OP:
Do you need push arms, linkages, tilt cylinder(s), etc, or just the bare blade.?
What S/N of machine is it going on.? I see a load of different D8T SU blade Part Numbers.
Jnocano
Texas
To the OP:
AW401382, Push arm and blade, after doing some more research 25/30k seems more in line.
Jnocano
Texas
Is your machine an LGP configuration.?
If yes then what width of track shoes does it have installed.?
LGP or not will make a big difference regarding what blade option(s) will fit.
28" track shoes
28" track shoes
28" shoes are the widest available for a non-LGP D8T undercarriage configuration. (LGP shoes are 38" wide). There are obviously differences between the mountings of a blade over 38"-wide shoes compared to 28"-wide. That was the reason for my LGP question.
See attached for all the details of the push arms, stabilizer link, etc, applicable to your A4W-prefix D8T running 28"-wide track shoes. Having Part Numbers at least means you can search for what you need. I also added all the four options of SU blades that will fit on to that particular Blade Installation Arrangement
  • 539-9136.pdf
Jnocano
Texas
Yeah thankfully it is not lgp, it seems it may be harder to find a blade and arrangement to fit if it was.
Is there any chance you could share the same information for a U blade?. Thank you in advance adnd Thanks a lot for the previous help sir! Have a blessed day.
