D5k2 flashing red at idle
Chased
Texas
Ok I’ll do that. And no I didn’t realize that, thanks! I’d like to have a paper copy of the manual so I’m going to order one and get by until it gets here. Thanks for all your help!
It might be interesting to see what happens to the system voltage around the time the warning comes on.
Just a thought. If you bought a manual on CD or downloaded a pdf copy you could have it printed and therefore have both paper & electronic versions of the document for one price.
Chased
Texas
System voltage on the screen shows 13.6 right after start up. It gets up to 14.0 and stays there. Doesn’t change when light comes on. Stays at 14.0 when operating.
JD955SC
The South
Well that put the kybosh on the idea it was dodgy system voltage.
I'm sorry I have no more ideas on what it might be.
Probably yes but I wouldn’t rule a voltage issue out yet . Another circuit that supplied voltage to the ECM could have a fault resulting in low voltage in that use. I really wish I could post a case study I wrote up about a machine I had. It had seemingly good system voltage but a secondary power supply circuit to the ECM was faulty due to a failed relay. In my case on four fuses that the relay controlled circuits on had 8v when 24V was supposed to be there. High resistance in the relay dropped the voltage.
The two main power relay coils are pulled in by power from the ECM from CONN J2
Off the top of my head I can't see anywhere where a main power relay feeds to the ECM. One relay supplies power to one of the fuse box bus bars, the other one supplies the other.
As far as I can see the machine ECM power supply (4 different pins on CONN J1) all comes from fuse #1 which is direct from Batt+ not via a relay.
  • UENR0002-02 - Electrical Schematic.pdf
JD955SC
The South
Here's a thought. Corrosion/condensation/contamination on the #1 fuse holder..?
Pull the fuse out and give both it and the holder a good clean might be an idea. At least then you've eliminated another possibility.
A great check especially if this happens to be an open cab machine (Yes Cat still builds them!!!)
Chased
Texas
You know, it is an open cab and that top fuse box had water and corrosion all in it. I noticed after I bought it of course. I cleaned it up and replaced bad fuses. But I didn’t spend a lot of time on it. What’s the best way to clean that out good? That was 6 months ago.
JD955SC
The South
there is a company called innovative products of America they make all kinds of corrosion cleaner tools for different terminals download their catalog and look at it.
Make sure you disconnect the batteries before doing the work as the fuse panel has hot wires from the battery going to it. Clean those ring terminals well too. I’d consider pricing a replacement fuse panel also. I would certainly investigate replacement if I was hired to be your mechanic. Corrosion is a common fault source.
The information of the fuse box being corroded and water filled is an important clue that might explain some of your issues.
Chased
Texas
So I have been running all day. Decided to stop and check the part number for a new fuse box. I’d like to replace it but how do the wires come out of/go back in the back of it? Also, the F10 fuse burnt my thumb it’s so hot. That normal?? Don’t seem like it
Chased
Texas
Lol kinda figured that. Maybe it’s just the box?? Corrosion has kind of shown back up on that box and on fuses since I cleaned it last.
To change out the box, do I have to just cut the wires and they push into the new box or what?
mks
Southwest Cook County Illinois
None currently
For what it is worth.
Electricians have a nice set of paired numbered labels to use when changing out circuit breaker boxes. I’m sure something similar could be improvised.
JD955SC
The South
A hot fuse you say? AH-HA another important clue!!! a fuse is hot it means high resistance is causing it to heat up. What causes that resistance is what you need to find. Whether that’s corrosion or a poor connection or damaged wiring...This fuse panel bears much more investigating. There are modular blocks that plug into the back of the fuse panel mark photo, many photos, and transfer carefully. They just have release tabs don’t cut the wire work it with a pocket screwdriver and carefully
I bet changing this fuse panel and making sure your plugs that plug into it are all clean and in good condition will solve your issue
Chased
Texas
Oh, cool. Thanks! It won’t pull up the crimp tool on the cat site but I googled and it shows $1700!! That can be crimped with a regular crimper right?
JD955SC
The South
For that rework procedure I’d have to see what crimping is required this isn’t a “commonly available parts store” type crimping tool
