Stan R
I am looking to get a track loader around the 15k range, I have a lot of rocky fill to move and my tractor doesn't do it well,any recommendations to buy or to stay away from thanks
Very good advice. A new skid steer is $125K here in Canada, dozers are way more than that. And only buy a running unit is my recommendation unless you are super capable as these units are not the friendliest to work on. Some guys rent a mini excavator ( 5 ton ) and move the dirt or rocks into a pile and use a skid steer to haul as they move quite fast. Little money invested and in one day could move 20 dump truck loads or more, no headaches or surprise bils for 40-50K which is not much on big stuff these days. May be a solution and new expeerience for you,Double your budget and whatever you buy make sure tge undercarrage is good. 15000 you may find a usable machine but it maybe a money pit. For 30000 you may also end up with a expensive pile of repairs
That technique works well and in an 8 hour day of non-stop there is a lot of material moved, spread, or loaded and no repair bill to have to deal with. Even a 5 ton excavator can swing and dump into a pile or multiple piles a lot of material in one day. A 410 Deere or a 590 Case with good size bucket is strong and pretty fast.a regular Tractor Loader Backhoe (TLB) can also move large volumes by mining it as @Simon C posted above, then flip around and move that loose pile and repeat.
The key improvement is you can move along pretty quickly if you grade a haul road for it.
What size are you looking for? Any particular brands?I am looking to get a track loader around the 15k range, I have a lot of rocky fill to move and my tractor doesn't do it well,any recommendations to buy or to stay away from thanks
Don’t overlook the International/Dresser 125E or its little brother the 100E.Don't care what brand,I also looking to use it to haul wood out ,I have a mini excavator, 7300lbs,,and tractor with winch, both to light for hauling logs on steep terrain ,I want to get a 10-12 excavator, but can't seem to sell mine,I have a 20ft high cliff on my property near the house I wanted to trim down
No.I like that QC!
Do you have any problems finding parts?
