Cat XQ60 Generator HPFP Oil Leak
pbd05
Ontario, Canada
Picked up this unit a few months back, knowing it had a bad oil leak. Cleaned it all down and nothing was really apparent at first. After having it sit for a bit I found that one of the oil drain plugs had a bad o-ring, got that fixed up. After a few hours of running I'm not seeing some leaking from high pressure fuel pump. It seems like it could be the o-ring between the front case and the pump that's leaking.
Is the repair procedure just as simple as unbolting the pump, and swapping the seal? I'm guessing I have to bring the engine to TDC. Or do I have to go open up the front timing cover to unbolt the gear before pulling the pump? Would anybody have service procedure available for this? S/N CF900109
Simon C
Heavy Equipment Mechanic
Posting the Engine serial number and model number may help get more results. My bet is that the pump needs to be timed before removal as per shop manual instructions.
Simon C
pbd05
Ontario, Canada
Once again, big thanks Nige! I'm seeing 512-7948 for the seal. Looks like the gear does need to come off to get the pump off the engine, not really what I was hoping to see.
