Tenwheeler
????00D6FUFBH0260 Has about 100 Lbs freon charge and appears compressor will not engage. All of the fuses and breakers at the right door hinge ares test good.
Air flow in the cab is good.
Snow flake on the A/C switch lights up when depressed.
Pressure switch behind compressor has power on both sides.
Two other two wire connectors, below the alternator, show no power with a probe at the back of the connectors. They are hard to get to and would have to remove the alternator to possibly unplug and test them better.
Wondering if there are some relays and such somewhere? Anyone have a wiring diagram for this machine?
Thanks for any help available.
