Ncjetskier
Serial number MHK07347
My oil pressure normally reads 40 lbs while working the machine. Now the gauge is pegged to the highest reading. The machine runs fine without any problems.
I changed the oil today and before even starting the machine (the machine had not run at all today) the oil pressure was almost as high as it can go - this was just turning the key but not starting the machine - just after changing the oil. Something must be stuck (sensor?).
The first picture is the gauge after just turning the key (machine not running). The second picture is the machine running.
Can someone give me some help in where to start to pinpoint the problem. Thanks!
