Brian Sanders
I have a cat d5g sn 5XK37095 that will not consistently start. The parking brake light on dash goes on and off (with the switch)so I don’t believe that is the issue. Batteries are new and charged and when I jump the start relay? (12v directly to starter solenoid wire By the circuit breakers) it will start right up. The prelude system is working and building oil pressure just no 12v to the starter solenoid to crank. I know it’s a loose wire or bad relay or solenoid but having a hard time following the wiring. Does anyone have a wiring schematic for this thing? Thanks in advance!
