coloradoinsane
OK so here's the back story. We just bought this 1998 D5C hydro dozer. Had been using it intermittently but not for very long until we noticed It has been starting to overheat. Found the oil cooler plugging due to an oil leak. Now that we were able to use it longer we are noticing a couple other issues. It is starting to bog and lose power especially going up a hill. I changed fuel filters again which seemed to make a difference for a little while. Noticed when I went to prime the fuel system that the seal around the priming plunger was leaking fuel out. When the head and replaced the priming pump. Once again seemed to run good for about 2 hours until started having the same type of load issue. Ran a new rubber fuel line from the tank in case of obstruction and ran air to the tank in case of debris. When disconnecting the fuel Line upstream from the water separator and fuel filter I do get gravity feed from the Fuel tank so i'm not thinking that we are dealing with a plugged line there. No black smoke coming from the engine so I know it's not overfuling.Definitely seems to be getting starved of fuel. Ideas?
