Cat d4 basket case
yrens
minnesota
Fantastic update
Great news today. With the pony motor being the weak link prior to today, I’m happy to say it appears to be running better then ever with a new cap, condenser. But it wasn’t fixed until I installed the new points that did the trick. All this time it acted like a fuel/air issue prior to no spark. But it turns out to be the ignition that must have slowly going that created the head scratcher until finally it went.So I immediately started with engaging the starting pinion and worked on getting air out of the fuel system. I got close with some black smoke but no cigar just yetI’ll try and post a clip, but I have a big question?? I had one fuel line from the injection pump to injector that was leaking at the nut. Turns out it appears to be missing a spacer which looks to be part of the fuel line. Any ideas on how to get this? Picture shows one end good the other missing.
Jeff
yrens
minnesota
Fantastic update
Jeff
Fantastic update
Jeff
I may need help on the YouTube clip. I pushed the film icon on top and embedded the link however I don’t see it posted?
Lumberjack Matt
Oregon
Lol, I just had that same exact issue with that little ring missing on my injection pump and the line leaking. Fortunately I found one off a spare line that broke into 3 pieces, but I stuck it around the line with some grease and it sealed up.
If I had to make up a new one, I'd look at the hardware store or at McMaster for a spacer where the inside diameter matches and cut it in half to get it on the line. Others here might have a better idea though. Sounds like you are close!
D5Dan
Oxford, Maine
Pony motor sounds great…congrats on getting past that hurdle…extra credit for pics AND video!!
if your pulling fuel from original tank and lines, have a couple fuel filters since you’ll likely catch a ton of crap in the first one/two filters.
Not sure how to handle that line fitting…but I think you have the problem identified (air leak).
Keep digging man, you’re going get it!!
yrens
minnesota
funny! Yea I was even wondering if I could put a few rubber o rings around it and that might seal it.
yrens
minnesota
Thank you. It was a huge day for sure. There is a aftermarket inline fuel filter which I just replaced prior. I will definitely keep my eye on it.
Lumberjack Matt
Oregon
O-rings wont work, it needs to be something solid to help that nut clamp down on the flare fitting. If it's leaking there, then the injector won't be putting much fuel into the cylinder. Assuming you hit the 3 air bleeding spots in the correct order (lower tower, upper tower, injection pump nuts), you shouldn't even really have to bleed the lines to the valves, but its a good way to check that fuel is getting all the way up there. Don't be afraid to give it a tickle of starting fluid once you get all the injection leaks sorted...
yrens
minnesota
I hear you. Take a look at the pictures. I used a grommet which is pretty solid and a tad thicker then the original spacer. I’m confident that it should give enough fill to push down good and seal tight
yrens
minnesota
Although you have been there before me so I’ll trust your opinion.
Jeff
oarwhat
buffalo,n.y.
I doubt that will work. It needs to be metal. The pressure in that line is probably over 1000 PSI. Something like a bushing cut down and split in half would work.
yrens
minnesota
Well I was planning a backup plan of making a bushing like you said. Also I have a guy just south of me approximately 40 min drive who has a parts machine and had the line. He’s a bit hard to get a hold of to swing down and get what I need.
I don't know if anyone has suggested this yet, but you really need a Parts Manual - or at least access to one.
I don't know if they are still available from Cat but with a Serial Number I can certainly have a look. I did have a poke around and found
The other option is to register on the ACMOC web site - www.acmoc.org/ - and look in their library of old manuals. you can have access to them once you pay the subscription.
yrens
minnesota
You are correct. I have been planning on doing one or the other. Meaning the ACMOC or find a manual. What do you think? My serial number is 7U3349
yrens
minnesota
I believe they do. And it’s $40.00 per year. So I guess it’s worth a try.
Lumberjack Matt
Oregon
I'm an ACMOC member. The scan quality for the 7U and 6U parts manuals isn't the best. It's really something that's nice to have a physical copy of, and the eBay reprints are decent quality, very easy to read all the numbers, and cheap.
The service and operators manuals are good quality at ACMOC, those are worth the price of admission. You can also get the service manual for the D315 engine there too, which you will need. There is nothing engine related in the 7U tractor service manual.
yrens
minnesota
Okay I’ll probably get a hard copy then. I have the other two (service/overhaul) which were a must for sure. Thanks.
