CAT 963 - Right Machine?
BackertheBiker
Indiana
Latest progress on the lake. The ol’ 655C has been working her tail off! Have all the trees knocked down that I need to - about 4 acres worth. Got a logger coming in the next few weeks, and I’m getting a pretty fair deal on the timber. Moving along here!
BackertheBiker
Indiana
Heard you all might be interested in an update... Lake is coming along! I got all the trees knocked down, got a logger to come get the sellable timber, and I’m almost finished pushing and burning limbs and leftover stumps, logs, etc. Moving along nicely!
BackertheBiker
Indiana
I do have a burning question now though..
I have been able to convince a friend to loan me the CAT 963 I was originally banking on. Needing to get it hauled to my place soon. See the photo of the machine below.
Can anyone help me identify this thing further? I beleive it's probably a 963B? And I'm trying to figure out the weight of it, but what I'm finding online is all over the place. I saw as low as 19.4 Tons, and as much as 55k pounds. And I think these are probably both well away from reality - my best guess right now is 44k pounds / 22 tons. Anyone have any better insight here?
BackertheBiker
Indiana
Update. No ripper, a rear bumper, and a 4-in-1 instead of the standard bucket will put about 2500 pounds on top of the standard machine. In total somewhere around 43-45k pounds.
Agree with Nige, need s/n. Smaller 'Cannon' track adjuster indicates Plain Jane 963 along with Smaller windows and doors of Cab. Wish had that here.
Thank you Gentlemen. I was guessing 44k. Working on finding someone to deliver it for me.
BackertheBiker
Indiana
Did you clear and grub all of that with your backhoe? If so God Bless you as you have the patience of Job.
I did / I have. Put about 300 hours on the backhoe since the start of the project. It’s been a job, but it’s fun work. Gonna try to put the dam together myself too with the dozer above.
And believe it or not, I’m doing this with a full time job, a 15 year old in high school sports, and I’m a single man so I take care of all the house chores too. I basically haven’t done anything else all year - when I have 10 minutes, I’m working on the lake!
Now that's determination! Well done!
IceHole
AK
Dunno how people with young kids do it. At least by 12-13ish they are generally usefull enough to be a helper though.
I've brought the dog out on jobs and hours later realize I hadn't seen him for a while.
Forgot I put him in the truck once. Was whining he was cold. Like 2 hours later I'm thinking ****, where did he go? The ocean is nearby, a creek as well and it was probably -20* I walk out to the truck to go track him down fearing the worst and derrrrpp.
BackertheBiker
Indiana
My daughter has been out here with me through the whole process of buying the land, putting a driveway in, clearing and building a house. Since she was 6 years old. She’s been a hell of a trooper through it all. Used to fall asleep in the back seat of the truck at the land, more often than in her bed at home. She’s a smart kid with a great attitude though, so it’s been easy with her. A different kind of kid could be a totally different story.
Georgia Iron
USA - Georgia
Concrete building slab and grading contractor
Looking good. I can appreciate the work you are doing. I purchased some land that has a pond on it. It was supposed to about 8 acres when full. The dam is 30' high it seems and covered in big trees. It is also steep and the lower side of the dam is very wet and swampy. It has a corrugated pipe threw the bottom with a 1" thick solid black sandpipe that is about 12 or 15"s round I have not been able to look into it since the pipe comes up out of the water and into the air. Lake is about an acre now and it is about 4 or 5 feet deep I got in and found a gate valve near the pipe.
Mine has a leak coming threw the dam about 5 or 8 feet away from the pipe. There is so much dirt there and no good way to try to dig into it. I have yet to come up with what needs to be done to fix it with out spending months to work on it.
So I would definitely take your time and do it right.
Cheap "old" Geezer
There is a Porous layer or a failed compaction layer in the Dam, will hate to hear but unless want to experiment with truckloads of Bentonite will need to remove everything including draining the pond to restructure that levee.
BackertheBiker
Indiana
Hey guys! How am I doing here? :D
I took delivery of the 963 last Wednesday afternoon, and got her hung up Wednesday evening.. You guys weren’t kidding that these things get hung up easily! And maybe more-so what I didn’t realize, is that it doesn’t help itself out of a sticky situation like the ol backhoe does..
I was basically driving around, getting the hang of the thing, and decided to go down a small incline to push some trunks around a little. Apparently hit a wet spot, and when I tried to reverse up the hill, I sunk instead. Should have stopped there and waited a couple days for it to dry, but I got impatient. 4 full evenings of working at it later, I got the damn thing out tonight..
Few questions for you all, now that I’ve had some time to operate the machine.
- It pulls left when going forward, pretty noticeably. I think I read there’s an adjustment for the motors somewhere? I’ll share the serial number plate in the next post - think I can only share 4 photos at a time here.
- When reversing and rotating counter-clockwise, so using the right brake, it seems to be weak. Doesn’t turn nearly as well as the other direction. Maybe related to above?
- After warmed up, when I idle it down, it has low oil pressure and the light and warning buzzer come on. How concerning is this? Anything to check, or is that just a feature of an 8k hour machine?
- Is the chassis not grounded on these machines? Or perhaps is it positive ground? The negative battery post was hitting the engine cover / door, and was arcing. I was surprised my this - thought the chassis would be negative ground.
Thanks All!
- Backer
I'd suspect it's 24 volt with 2 batteries? Then the negative on 1 battery is connected to the positive on the other so it may be the positive current flow is actually arcing. Fix it so the door can't hit the battery post or cable connection. You don't want to fry any of the electrics or electronics. My battery cover is very close to the top of the battery so I have a thick piece of rubber over the top of the battery posts.
Georgia Iron
USA - Georgia
View attachment 312764View attachment 312765View attachment 312766View attachment 312767
Thanks All!
- Backer
It's a pretty quick learning curve. If you ever can't get it out and you need someone with bigger machines on-site you won't be happy. I know ofa guy that lost his 53 that way. It settled on in during the night. 4 machines to get it out and the motor was ruined.
Rule of thumb is if you feel it slow down you better watch out.
I would avoid all the wet areas it not worth it. Those lovely videos of dozers cleaning mucky lake bottoms on YouTube can make it easy to loose perspective. They normally have rescue equipment on site and know when to hook it up.
One of the worst things is taking out a stump and falling in the wet hole or jambing the stump and it grabbing the skid plates and making you high center.
I have spent a LOT of money on recovery gear and big winches.
