Cat 963 repairs
Spyros33
Korinth, Greece
Mechanical engineer, machine operator
The shaft was worn too so it had to come out for machining. Man that thing was hard to remove! There were two threaded holes on the flange that are supposed to eject the shaft by inserting two screws but that wasnt enough. Had to use some Wedges and a lot of brute force!
Spyros33
Korinth, Greece
Ιdler needs new bushings
That bearing assembly was also really Hard to remove and even harder to unscrew the flange in order to get that bearing out
Spyros33
Korinth, Greece
11 out of 12 bottom rollers were shot
Starting from the rear side, the rollers on one side were S-D-S-D-D-D while on the other side
Were S-D-S-D-D-D.
I think the second is the correct sequence. Can someone confirm?
Bluox
WA state
Were S-D-S-D-D-D.
Yours should have a single next to the front idler and the rest are correct.
Usually roller position is called out from the front to the back S-D-D-S-D-S.
Bob
Spyros33
Korinth, Greece
Hi guys,
Things are going pretty slow due to lack of time. We started the assembly today and hopefully we will finish in the next weeksIMG_20210629_131129.jpg IMG_20210629_131109.jpg IMG_20210629_131050.jpg
New rollers, repaired idlers and new bucket blade and teeth
The old teeth are just perfect for my 955 bucket
Spyros curious why you are taking the teeth off and putting a smooth cutting edge on that 963?
shane637
Ct
I know this is a couple of years ago, but we are rebuilding pivot shaft on 86 963 machined spindle and having a tough time understanding how the seal is supposed to be installed in hob on pivot, any more pictures? Thank
