CAT 938f quad gauge issues
Caincon
MA
I have a cat 938F that we have been having issues with the quad gauge monitor that shows , fuel , engine temp, trans temp and hydro temp . When you cycle the key the gauges will sweep as like they are supposed to however 80-90% of the time none of the gauges will read . Every once in a while running the machine the gauges will come alive , read correctly then go out. Recently the gauges began working ( they worked for 3 or 4 days which is the most we’ve ever had them work. Got in machine today and once again they are not working . We did order the quad gauge monitor and that did not change the issue . Any help is appreciated
Caincon
MA
Attached is serial#. Yes we originally believed there was an internal issue with gauge . Clearly that was not the case …
I'll send you an electrical schematic. Keep an eye on your message inbox.
A couple of questions for a start: -
1. Do all the gauges in the quad gauge assembly sweep full scale every time when you turn the key to ON.? The "every time" part is important.
2. Does the tachometer/speedometer display behave the same as the quad gauge assembly when you tuen the key ON.?
3. Does the speedo/tach module display correctly when the machine is operating.? In other words does it show ground speed, engine RPM, and the selected transmission gear.?
Caincon
MA
Sorry for delayed response . Gauges only do 1/2 sweep. To my knowledge they used to full sweep . It appears now it is only half sweep. This machine does not have a tac/ speedometer , it just has the gauge set with hour meter , and warning light set above . I tried to upload a video of the gauges but I for some reason can’t upload . Will attempt
To upload .
Caincon
MA
I believe the icon disappears , but I will
Double check tomorrow. Thank you for
Any assistance you can give NIGE
I tried to upload a video of the gauges but I for some reason can’t upload . Will attempt To upload .
You can only upload photos. To upload a video you have to host it somewhere else first then link it in a post on here.
believe the icon disappears , but I will Double check tomorrow.
Whether the SERV CODE icon disappears or not after the boot-up sequence will be key to how the diagnosis moves forward.
TVA
USA
I’m sorry for being rude - but what was the logic behind replacing the gauges, if they been sweeping OK all this time?!
I apologize again!
Caincon
MA
We replaced it because because we thought it was an internal issue inside the gauge cluster ….
Nige will confirm this tomorrow . Thank you
Caincon
MA
So Serv icon stays illuminated and lists the following codes image000000.jpeg
Caincon
MA
Attached is additional codes
TVA
USA
CID 248 FMI 2 might be it.
Communication issues? Data received not expected.
TVA
USA
Also Coolant sensor, ECM low voltage detected and particular trap inlet pressure sensor, downshift solenoid.
TVA
USA
See if you can find twisted pair of wires going to that module, check the connection, put the ohmmeter across them and measure resistance should be 60 ohm. If it is 120 ohm - you have problems with terminating resistor.
Don’t shove multimeter probes in to female sockets if the connector - just touch them.
Caincon
MA
Ok will try this this tomorrow or Saturday , thank you for the info , is the terminating resistor something that can be changed ?
TVA
USA
Yes. And they do go out, or get bad connection. It should look like a two wire connector that plugs in to wiring harness. Nige should help you with locations.
But then again - usually they create more mayhem than one component malfunctioning. But they make network do weird stuff.
