ldequip
working on a cat 730C (CAT730CLTFF00470). customer had replaced the turbo and said it was smoking badly. He called and i gave a quick look and removed the turbo again as it was leaking oil. not sure if he messed it up but it was a brand new from Cat turbo. the engine did not start smoothly at all with new turbo and could hardly keep itself running at idle. he says it didnt do that before. i gave it a strong dose of injector cleaner and tried again. after 30 minutes or so it cleared up. and i thot possibly but with 15K hours it may need a new set of injectors. it still is not running well. customer says it is making oil -- assuming he means the pan is filling with fuel
... anything else to think of before we go for those injectors? anyone have the tech book for that C13? it does have a jake
