CAT 725 TRANSMISSION REMOVAL
JOHN.B
Michigan
WE HAVE A CT 725 THAT NEED TRANSMISSION WORK. I AM LOOKING FOR PROCEDURE TO REMOVE THE TRANSMISSION. WE ARE THINKING CAB REMOVAL IS NEEDED.
Welcome to the forum @JOHN.B
A point of forum etiquette you may not be aware of. Please don't post in all capitals. It's considered the same as shouting.
You are correct that the cab needs to be removed, along with the crankcase guards.
See the attached procedure. If you have any other questions please ask.
  • Trans R&I.pdf
