Cat 424D backhoe loader no forward or reverse
Mr tlb
South africa
Good day
I have a caterpillar 424D backhoe with serial number RXA
Machine has lost the ability to move forward nor reverse
Checked for power on the solenoids located ontop of transmission
They have no power.
Also checked the wiring harness to the solenoids no power
Looks like there is no power to both solenoids
All fuses good
Both solenoids tested on another machine,& they seem to work fine
The white wire ( ) seems to be having power checked on the fuse box and also
Any assistance will be highly appreciated
ador
Philippines
Sir, wheel Loader Liugong clg 856 model 2013.only working forward/reverse.2nd,third and fourth gear not working.what are possible causes?
Mr tlb
South africa
I sent you an electrical schematic. Check your message inbox.
Thanks, received and went through the schematic.( not soo easy to understand)
discoveries
no power to forward or reverse solenoids
diagnostics: -
tested forward and reverse handle on known good backhoe & it works fine
tested both solenoids on known good machine & they work fine
When testing FNR plug wires, the white wire has power, all other wires no power
when trying solenoids manual by pushing with a pin either to reverse or forward position the transmission responds therefore my issue is electronics related not the transmission
could it be the neutral safety switch or key switch relay (cant find their location)
TVA
USA
For a moment I’ve got exited, and thought “someone got 424 in the USA?! o_O. Then I looked at OP’s country.
TVA
USA
discoveries
diagnostics: -
Neutral safety only job is not to let your starter work when you are not in neutral.
There’s should be two wires in the FNR switch that do that.
If you have power feed to FNR - get the multimeter in to “buzzer mode” and start testing whether the FNR switch is switching OK. Put one lead on that supply contract, start switching the switch and test the connection
TVA
USA
Another thing: are you sure your machine is getting off of the parking brake?
TVA
USA
OK I’ve missed something there. Not sure about this particular machine, but most of the times there should be two wires under power: one is for neutral safety switch, the other is for FNR.
Looks like you are missing one. Or I’m wrong
Mr tlb
South africa
thanks for the reply,
the electric parking brake? the switch has power when testing with a multimeter
toight i got hold of a 3 way toggle switch (ON / OFF / ON ) that i gave direct power from the battery and connected it to the FNR solenoids, machine does move forward & reverse
so it seems i lost power to the solenoids wiring or to the FNR handle plug because the handle works fine on another machine
Mr tlb
South africa
any idea where the neutral safety switch is located on this particular machine?
Simon C
Heavy Equipment Mechanic
I could find the component on the schematic, but I think that lots of people find it harder to find the location off of a PDF. It took me some time to learn how to follow the wires. Plug in locations, and relay and solenoid locations are easy to find if you know how. Maybe the member is having a hard time to find it.
Simon C
Mr tlb
South africa
Simon C
True
It's really hard to follow those wires
Mr tlb
South africa
Do you mean the transmission neutralizer switch.?
Is it not #5 on the top of the transmission control lever.? See attached.
the switch on the gear lever im aware of, when testing power to it,there is no sign of power, tried the neutralizer switch on the front bucket lever there is also no power to it..
seems that the only active neutralizer that has power is the 1 on the FNR lever
If that's the case I'm baffled as to why you were asking where the neutralizer switch was.?
The function of both neutralizer switch circuits is not to carry voltage/current but to provide a path to ground so that the Shuttle Control will recognize if the two switches are open or closed.
Whichever of the two switches is operated the logic is the same as far as the Shuttle Control is concerned. "Do I see ground on Pin 9 (one or other switch is pressed) or do I not see ground on Pin 9 (neither switch is pressed).? If I see ground do A, if not, do B."
A resistance/continuity test on this circuit might potentially give false results.
Use a decent wattage test light connected to batt+ and apply it to Pin 9 on the Shuttle Control. Press each of the neutralizer buttons in turn then release. Does the test light come on each time.?
