Hello Friends,
I have read this forum for several years and enjoyed it thoroughly. Over the past year I have been resurrecting a Cat 320 serial number 2DL01890. The machine had been setting for more than a decade and was considered scrap when I started. It is a very used machine but will be an incredible asset at the farm where it will dig ponds and and be a great partner to an old Volvo loader that I am also working on.
The 320 now starts and runs smoothly at an idle speed. Turning the engine speed dial does show on the digital display as I turn it up and down but the engine speed stays at an idle. I have checked all the fuses I see in the fuse holder. I have confirmed that the solenoid on the throttle is moving freely and the engine responds by manually pulling on the throttle.
Can you help with suggestions on what I should check to continue to track down the problem?
Has anyone seen this in the past?
Second line of thinking, This is a very old machine that has very little computer control. if it is determined that the problem is in the computer, I won't be replacing it, instead I would be figuring out more direct rpm control either manual or a separate speed control. Has anyone else followed this path?
Thank you,
Nolan
Thank you,
Nolan
