Cat 289D fuel pump not priming.
dzlsnowman
USA
Hey guys, EVERY time I change filters on my machine, the fuel pump stops working and won't prime. What am I doing wrong??? Last time this happened I replaced the pump, I highly doubt this needs done again since the pump was working just fine when I shut it off to do filters.
Is this the same TAW09660 machine you posted about before.?
Was the replacement fuel pump you installed previously OEM or aftermarket.? Part Number.?
When you asked before I did mention that there was an update to improve the reliability of the fuel transfer pump applicable to all TAW machines up to S/N 10068, which would include yours.
dzlsnowman
USA
September of last year. Still doesnt make sense that it worked fine until I changed the filters, this happens every time.
heymccall
Western Pennsylvania
On my old 248B, you had to leave the seat bar up, and turn the ignition switch to "Start" briefly. Then, the pump would run. It wouldn't get voltage in just the "Run" position, with the engine off.
If you left the seat bar down, it would start (and run for a few seconds, then stall) on the fuel left in the lines after a filter change.
