Cat 259B3 fuel issue when hot
Frank Nesbitt
Madison georgia
I recently acquired a early (YYZ05843) CAT 259B3 skid steer. When cold, the machine cranks and runs fine. Lots of power and no skipping, smoke...nothing out of the ordinary. After running just 5 minutes or so if the engine is cut off it will crank back up if tried in 10 seconds or so. Wait any longer and forget it. Acts and sounds like no fuel. I have checked the electric primer pump and verified fuel is getting to the injector pump. I have opened an injector connector and get almost nothing in the way of fuel except a spit or two. I would assume (yes I know what this means) the high pressure pump has issues. Since I have never torn into an injector pump does anyone have any suggestions? Is there something else I could check before spending $ on pump? Thanks for all relevant suggestions
heymccall
Western Pennsylvania
Frank Nesbitt
Madison georgia
Heymccall, thanks. I have replaced all fuel lines and checked the filter head and chrck valve. I will remove the bowl tomorrow and make sure it is installed
heymccall
"Checked filter head?"
Unless you physically verified no debris between inlet elbow and the concentric tube (by removing inlet fitting, primer pump, filter element, and entire head assembly), then you haven't checked it to my satisfaction.
I only emphasize this because I don't have enough fingers and toes to count the number of times that I've been dragged out to a machine that has been checked over "thoroughly" only to find a missing bowl Oring, or debris blocking the filter inlet.
It's your machine.
Also, electric pump "prime" enable is stupid weird, and not like in the book.
So, next time...
When you think it's not getting fuel, enable the "prime pump" by leaving the seat bar up and turn the ignition to crank for a second, then leaving it in run for, say 20 seconds.
Now, retry starting it (sitting in seat with bar down).
In other words, the electric pump won't run if the key is only turned to RUN.
Frank Nesbitt
Madison georgia
Yes, head was completly removed, fittings and filter. Taken off the machine and verifird no blockage. Like i said in first post i verified fuel to the injector pump. No air in sample taken at pump just good clean fuel. Not getting from banjo fitting at inlet to injector. I did verify fuel returning to tank from system when running the primer pump. As for the pump i did not use the switch. I wired up a hot wire to a momentary switch so i could verify what was going on when the pump was running.
Unit has sat for the last 6 hours and when tried immediately got fuel to injector 1. Tightened fuel line at injector and it fired up no skips or smoke. Ran 10 minutes and turned switch off to bleed hydraulics for attachment. Unit would not start back up.
Frank Nesbitt
Madison georgia
My banjo connections are on the injector pump. The nut at the injector is where i get a little spit of fuel. The supply and return lines at the injector show no signs of air. ( used clear container to catch sample)
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Be careful when checking anything at the return on the injector..
A> it wont tell u anything
B> some of those return lines run back to the filter head.. so if your running/diagnosing anything at the return line, your introducing AIR into the system.. thru thr filter head..
Frank Nesbitt
Madison georgia
Ok, finally got results. After hours of fuel line replacement, watching bubbles, changing filters, searching for someone smarter than me i have an answer. My issue with unable to do a hot start has been fixed with an injector pimp. Took mine off and had bench tested.......low pressure when hot fuel got into injecter pump. Estimate of 900 to rebuild. CAT had a sale so i got a new pimp with free shipping. All total 1300 dollars. Old CAT purrs like a kitten..... Thanks for all the informative answers on this site.
