bubba327
I have a cat 247b and my switch for my aux hydraulic on my joy stick doesn't work properly.
If I push the button in the up direction you can hear the machine "bog down" as in the switch is working. Once I push the switch in the down direction I get nothing. In other words if I have a grapple on the machine it will close it but not open it.
I took the joystick apart and wasn't able to see to much. Everything looked to be ok, no loose or bare wires, and everything was tight.
I'm not sure where to start looking or what to start looking for. Fuses, relays, etc. I've seen other people say they replaced the whole joy stick and had the same problem afterwards.
Thanks for the help!
