Cat 226b thumb wheel switch replacement
wriggconst
Thanks, I will take mine apart and try to repair it. I can't hardly believe that a replacement switch is not available.
wriggconst
I will be going back to the machine in a couple weeks and take it out. I'll take it out and look it over. l may send it to you if I can't fix it. Thanks Wayne
Johnny Albarado
Uvalde texas
Has anyone found an aftermarket thumb wheel switch that works on a cat 226b skid steer it's on the right joystick . Mine has gone completely missing and the replacement is cost too much. Is there any alternative switch that can work in its place to get the auxiliary working again. Even the the data sheet for the switch would be useful.
Johnny Albarado
Uvalde texas
Any leads on thumb wheel?
wriggconst
Do I just cut the wires or is there some other to get it out? Thanks,Wayne
quiksilvr
california
mad scientist
For those who are wanting to send me their thumbwheel switches, i want to make it very clear that i am by no means an expert at any of this nor do i guarantee that ill be able to fix your switch. I WILL try my best to fix them. Im saying this now bcuz i dont want to mislead anyone or have anyone get their hopes up in the event that im unsuccessful at fixing it.
Goncolgo
N. CA
257B2
My thumb switch is a little stiff, is there a lubricant that can smooth out the action? If there are any updates on an available replacement switch I’d like to keep updated.
257B2
Try some type of silicone spray. Failing that you may have to (very carefully if the switch is working at the moment) disassemble the switch and clean it inside.
