If you can post a photo of your relay setup that will help us to help you.My relays are top to bottom set up, but I will do that in the morning, if you don’t mind.
I'm not sure I completely understand. Does that mean you have power back to both halves of the fuse panel now.?So, this morning, all fuses are getting 12v
On your photo there are some weird "colours" on some connectors around the relays. A sign of condensation/corrosion maybe.? Open everything up, get in there with aerosol contact cleaner as a start.Now, as we chat, the fuses are barely getting readings, earlier this morning I was getting full voltage
What do you measure across the battery temrinals.?I’m getting 10.6 v at the 3 terminals and buss bar
11.91What do you measure across the battery temrinals.?
