Per every parts manual I found, part number: D143162 When I search for it, it's replaced with 182445A1
Pictures looked right as far as the ports facing the correct directions and the bore/ear locations. However, what arrived does not fit into my firewall (if it's still called a firewall on heavy equipment). The new ones are smaller in bore and in bolt distance. The old ones fit snug into opening, new ones do not, and the bolt holes aren't even close.
I've spent all day trying to find an alternate part number for a larger version of the same part, no listing I find will specifiy the bore diameter or the measurement between bolt holes in ears, and nearly every listing I find has 580sk in the list of compatibility. The stamping on the old one I have off yielded zero results.
I can't be the only one who has run into this issue. Someone please advise!
I'm just going to have to put it back together with the bad cylinder for now.
Thank you in advance!
