Case 580E - Trans or Hydraulic Problem? Won't move.
hookedondiesel
Sault Ste Marie Ont. Case 1835C
I did a bit of research on "Google" and found these....
A159506 580E CENTER WHEEL (TRANSMISSION RING & PINION) was $125.00 "used" out of stock"
A157462 $53.75 (spider gear)
A153711 Case Spider Gear Pin $25.93
A140705 ROLL PIN $1.30
A179107 New Case Backhoe Right Hand Side Gear $297.50
A156376 Differential Cross Shaft $432.00
RonG
Charter Member
Meriden ct
heavy equipment operator
I ran a 580K that was not going in gear all the way due to bad motor supports,something to check for you.Ron G
Bill Smith
The Near North
Rental House Owner
I think the year of a 580 SE with only 4000hrs for salvage was burnt or stolen and striped for parts if not thats only a 142 hrs per year,,,, na don't think so
Arkansas
Hey buy a shuttle rebuild kit on eBay for 130.00 dollars. You don't have to take the whole transmission out. Just the back shuttle case. It's 6 bolts on shuttle 4 on dtive line and unhook 3 lines. My 580d wouldn't climb hills or even move other then reverse. It took 3 hours to do and now it's like brand new. Hope this helps. If you need more info and pics email me at [email protected] for pics and info.
Coy Lancaster
Arkansas
service tech
It sounds like you have got quite a bit of work to do on the old girl. Check with "Reliable aftermarket parts" I have found that they have the best prices on equipment parts. I usually talk to William @ (571)992-6157 this is his direct line, main company number is (888)672-7876. Look up all parts needed @ partstore.casece.com or use bing and search for Case online parts catalog. Good luck and hope you get her fixed.
Tinkerer
I dunno Coy,
Gregory Johnson resurrected Farmer20's thread that died in 2015. I sure hope he got it fixed. But, like so many guys with problems they never post back how or if they got something repaired.
