I have a 78’ Case 580c yesterday it shut off after letting it idle for about 6-8 minutes. Then when I went to drive it off it lost RPMs and shut down. I assumed a fuel issue so this morning went out and checked to see if I was getting fuel before the fuel pump and after the fuel pump. Cleaned the fittings and then started it up. It worked great for a while. Left it idling while I went to start up the small tractor and it had shut off. Cranked it back up and it didn’t same thing. I was still thinking fuel delivery issue because that’s what it felt like. I waited two hours went back out and it was running good for about 30 minutes. Then I started to notice forward was getting slower. RPMs were going down. When I dropped the bucket Rpms went down more, couldn’t get them to go back up with the throttle lever. Went to put the stabilizers down and it bogged out and died. Now I’m not sure if it’s an actual fuel issue or something else. Please help. THANK YOU!
