Case 450 alternate belt change
Tinkerer
usa
No tricks.
But if the hydraulic pump is bolted to the front of the engine crankshaft, the coupler to it has to be separated to get the belt through.
It is then a good time to check the wear on the pump input shaft spline.
Sometimes the splines are seized and pump has to be unbolted to separate the two parts.
MG84
Virginia
What model/engine? On the 450C with the 3.9 Cummins you have to unbolt the hyd pump drive coupler and slide it forward on the splines. It's really not a difficult job, should take less than an hour.
I have a link belt on the wall, it’s for emergencies only.
Anyone that leaves on for a while is either lazy or has never had problems with one but they will.
When you’re a 1/4 mile out in the woods and it starts to heat up, because the link belt came undone or stretched too much and then they overheat the engine and crack a head and melt some rings and piston tops.
Been there, done that and my dad was furious. Was his tractor, not mine.
lol
