While most of this is pretty new to me it just makes me feel sick inside seeing what was a good usable truck torn apart, for no good reason. Reducing it to a pile of scrap, that just rusts into the ground. It must about tear your hearts out seeing this, since you grew up in the hay day days of the timber industry. Over the weekend I went to an antique farming and tractor show. To see so many old tractors, steam engines, and equipment is always special. Some are just sitting there after being rebuilt and painted up better than new. Others were out harvesting, running old equipment, that dates back to the 1800's to early 1900's. A few still had the original wood instead of tin construction. They even had four old tractors hooked together with flat belts, then hooked to the fan that lets them put a load on the tractors. Seeing three of them running two flat belts at the same time, was sure a sight to see. They have an old saw mill being run by a steam engine and flat belt, working. It has a 4' circular blade with replaceable teeth. All manual adjustment and log turning is done by hand and cant hooks. It is a great show with so many old machines being used, and only 8 miles from my place.
