Hi all, new to the forum so hopefully I am in the correct place.
My question is as follows and I am so grateful for any advice:
I made drive and tail drums for a client for a large tracked stacker, with large overhang at the rear (tail) end.
The head was specified as requiring dynamic balancing, and the tail static balancing.
This was done, but there was still bouncing at the head.
I looked again at the report off the balancing machine and it said there was only single figure grams of imbalance on either plane, so that could rule out an issue with the head drum, and to (what I thought) further confirmed this, was when the rear overhang was propped with a wooden skid, the bouncing at the head stopped, thus bringing me to believe that perhaps the tail drum should also be dynamic balanced. this was done, again within grams, and sstill the head was bouncing when the drum was refit.
I'm pretty sure the drums are OK but the client is holding it over me that it is because of the drums, I know that is a natural inclination, but the reports are stating all is ok with drums.
Is there anything in the conveyor system that could be causing this that I can go back to him and suggest it's something he should look into?
many thanks in advance for any input guys.
Drum mass is 100kg
service RPM is 162 RPM
Drum mass is 100kg
