I'm at a loss & need some help! I will be as descriptive yet brief as possible but, it's still going to be fairly long. I hope somebody can guide me through this.
2017 Bobcat T770. Deluxe set up. About 310 hours on machine. A few weeks ago right before shut down code M7028 SWITCHED POWER OUTPUT FAILURE flashed up but, everything was working as it should. Before I was able to get back to check the machine was put to use with a cement mixer attachment. About an hour into service the panel showed voltage drop (I was not the one using the machine at the time so this was relayed to me) down to 10.5 volts.
When I checked it with a multi meter thinking it was a battery/alternator issue, the battery was at 12.49 volts. By this time the display showed just 8 volts INSIDE the cab. Then, everything just went dead inside the cab. I could jump the battery at the solenoid & the motor spun full strength, so battery is fine. I checked the obvious things, grounds, fuses, mega fuse, connections, etc.
The unswitched/direct power fuses all have 12 volts on both sides. All the SWITCHED fuses have NO power at all. I swapped the relays, no go. I have 12 volts on the unswitched power wire on the starter switch 12 volts on the blue wire at the switch and when I turn the switch to START 12 volts goes out the TAN starter wire. The SWITCHED ORANGE/WHITE wire has 1.3 volts on it at the key switch all the time, and should have 12 volts when signal/power is switched.
I jumped the switched wire from red power and the display came on. It showed CODE R7404 MAIN CONTROLLER NO COMMUNICATION. That's all I could get off the display, nothing else came on or worked, I couldn't cycle through the menu, etc. IDK if the code 7404 is a true code or if it's because I bypassed something when I jumped the starter switch.
I'm not sure how to test the starter switch properly. It's a 4 pin switch with 5 wires that plug into it. I can't find anything on test procedures. I checked the 3 main harness connectors under the cab. The light & dark gray ones are fine. The black one had 2 loose ground wire connectors which I finally cut on each side & connected together outside of the connector. While doing the wiggle test, I suddenly got power to the cab, but lost it again before I could read the display/see if it was functioning.
Strange thing, when I had power, the headlights began flashing & the headlight relay was acting like a hazard signal relay but this machine doesn't have the hazard switch set up. When I went back up the following morning, the lights no longer flashed and nothing had power again. I have not been able to duplicate the flashing lights, or power restoration. I have gone over the connectors & harness for hours, nothing is evident. I checked for continuity on every wire on both sides of the connectors. The unswitched power wires have 12 volts, The blue wire (monitoring) has 12 volts. I THINK the yellow wire has 1.8 volts but should have 5 volts & goes to the controller.
I want to replace the starter switch just to eliminate the possibility...or am I wasting $?
Anybody have any ideas here or previous experience with a similar/same issue?
