Best Grease for Tractors, Excavators, and Chippers...
volmistral
Felton, CA
I am curious if there is a grease everyone likes for all-around use on their heavy equipment.
I have a Case 570 skip loader, Kubota KX057-5 excavator, and a Bandit 18xp chipper.
Seems like a lithium-based grease with moly - NLGI #2 is maybe the best?
Any thoughts on this or specific recommendations?
Lucas Red n Tacky? Case or Kubota OEM? Chevron?
Simon C
Heavy Equipment Mechanic
Some greases with 5% moly last longer on bushings and pins, but not sure about high speed bearing applications. They probably require NLGI#1 Or 2 from what I've heard.
Maybe someone else will chime in with some concrete on paper info.
Simon C
volmistral
Felton, CA
The Bandit chipper manual says to "use an EP-2 Lithium type grease only for all bearings" so might be ok overlapping with the other two machines?
I actually prefer Schaeffer if I can find it, for everything that’s not high speed. Their chain spray is the best in the market but hard for me to find.
Shimmy1
North Dakota
volmistral
Felton, CA
I realize there are a lot of grease threads and I read many before posting. Thank you for compiling these though - I have indeed now read them all. Nice to have all of these gathered in a 2025 post.
1) I am still wondering if people ever use the factory recommendations and OEM products (I read a lot of CAT but not much else)
2) Maybe to be more specific in my case, wondering how you guys might approach my setup. To have the right stuff but possibly one grease? Or two? Trying to hone this list down, and honestly not sure how all of these greases relate to each other. Will apply with electric gun.
Here are the factory recommendations:
Kubota KX057-5 Excavator
Shell Alvania EP2
or Mobilux EP2
CASE 570N XT Skip loader
Most everything:
Tutela Multi-Purpose EP 251H, GR-9
Bucket pivots:
MOLY LUBE 251 EP-M
Bandit 18xp Chipper
"Use an EP-2 Lithium type grease only for all bearings."
Coaldust
Subarctic Backwoods Trailer Park
Big trucks is what I know. HAZMAT is what I tow.
Using one grease will be a compromise. I’d use a lithium complex w/moly for your pins and a lithium complex without moly for your u-joints and ball bearings.
I used to get paid to wear a Chevron hat.
Delo ESI EP2 would be a great choice for all -around use and ESI HD Moly 5% for pins and bushings.
Mystic JT6 is another great choice. And, whatever the moly version is.
Just as long as you don’t grease like LMM? Too soon?
Just get something that smells good and the color works for you because if you’re like me and it’s grease time, I can wear all the PPP I want, there are not many times I don’t get grease on me, in me, all over me, especially if I have to change a tube.
Happiness, is when you go to the wall and find all your grease guns charged.
What sucks is when it’s 110 degrees out and the grease has melted out of the tip and you lost your prime.
volmistral
Felton, CA
That is really helpful. I grew up on a farm in a “Chevron household” myself but wasn’t sure which to get.
Curious, last week before posting I had ordered a 10pack of Lucas red n tacky but wonder if it should have actually been Lucas X-tra heavy duty (to match the EP Delo) for the all-around grease on these equipment for now?
Will get some 5% moly for the bucket etc.
cuttin edge
NB Canada
Finish grader operator
We have a seacan where all our lubricants are stored. Only different grease on the shelf, is winter and summer. They used to buy whatever was cheapest, but since not all operators are dedicated greaser. They buy Lucas products. Seem to last longer. We do have a different assortment of equipment, and it wouldn't be practical to use different grease for each. Only bad grease is no grease. Unfortunately, the so called adults that run things on both sides of the border, are making it difficult to buy American products, so we might end up using whale blubber
volmistral
Felton, CA
I don’t have much good to say about Lucas grease, other than it’s easily available. Separability is a thing and you’ll see the grease cartridges start leaking oil as it sits on the shelf.
Thx for the suggestions. Btw It looks like they have renamed these greases from Delo to Starplex.
volmistral
Felton, CA
October 23 is when the new branding came out. Something about combining the Texaco and Delo branding.
Ah. Picked up some Starplex Ep2. The 5% moly has actually been pretty hard to find. Mfg out of stock issue they think. If I start with 3% moly and then go to 5% when it's back in stock does that create any issues?
