Asking Recommends, Looking across all lines at Skid Steers
Have Locust Trees, in Abundance so track preferred, mainly looking at Good to Bad and what to expect as to service hours for from 2005 thru 2018 Units in the Class Categories around similar size 333 Deere, 239/249 series Cat for Reference to Sizing, 70hp Up and Hi Flow Tool Grade Hydraulics
Thanks Dave
heymccall
Western Pennsylvania
My Kubotas and Takeuchis all have self storing windshields (no swing out door).
Takeuchi tech support exists, Kubota tech support seems invisible. The Kubotas didnt take anywhere near the love to get to 3k hours that the Takeuchis do.
Kubota has the worst HVAC. But we can help you rectify it.
My money would be on a Kubota. I'm just not sure they make one that small.
Not against Heavier. 8-10k machine is good, just used the previous as a Starter.
Will be using Primary as Grading, secondary as Hyd Tools as Forward brush eater, eventually a Auger head and or Post Driver
BILs boy, our nephew will be using as a Severe terrain brush hog.
Coaldust
Subarctic Backwoods Trailer Park
Big trucks is what I know. HAZMAT is what I tow.
Everyday, I drift further away from the iron scene as my days are occupied with trucks.
With that said, all I see are new Kubotas.
Is it the financing and marketing? Are they just good machines? Are the dealers providing good service? Do the other skid brands suck that bad? Why so many Kubota’s?
Takeuchi here is a bit distanced of Service, parts. Closest is Fenton, and not a good rep there. Kubota has a Really odd rep with users and AC is one big hitter, Closest Support, Troy MO. Cat have Fenton as well, but also Foristell and CoMO. Deere is here in town HOWEVER the Pricing for a Name, Service dealers are everywhere. Bobcat is at Wentzville and a Service Dealer at Wright City. See oddballs as JCB, ASV and a few others seem they end up in low hour auctions so skittish there.
Size Classes? Rated on HP or Hydraulics? Weight?
materthegreater
VT
Careful of the Kubotas, they like to play dead
Must be a local/regional thing. Don't see many Kubotas here. Cat and Bobcat dominate the market with some Tak's thrown in.
Junkyard
Claremore, OK
Field Mechanic
Based on experience here I’d go Cat, Takeuchi and Bobcat. Cat doors are a bit of a pain swinging out but that’s rarely an issue. Tech support for Cat would be better, especially with HEF as a resource. A high flow machine in your budget would concern me a bit as the hours needed to get to that price point would put it toward the end of the usable hours before hydraulic system reliability becomes an issue.
There are some good brush mowers that will run on standard flow and that opens up some options for other machines. Having run 259’s vs 289/299 there’s a considerable difference in capability. Having said that, the TL12 Takeuchi is a hoss, before I left ** there were 3 purchased within a year and they’d work circles around the 289/299 Cats I’ve run. Kirby Smith is our Takeuchi dealer.
Bobcat support here is meh. We have one because the guy building pads swears by his. Rest are Cat we usually buy out of rental fleet.
Urbanengineer
USA
Gehl CTL 60, Takeuchi TL6 / 8, etc. all use similar* parts. All the guys I know that repair them complain about the Final Drive prices being more than the cats.
You can tow them without a CDL though which is great.
I realy like Gehls and wish my old 4625SX 's kubota wasnt trying so hard to die.
crane operator
sw missouri
I'm interested to see where you end up. I'm still renting when I need one, which is around 3-4 times a year. I can rent one for $350, and I've got the trucks to haul it.
I just can't get my head around owning a $25-30,000 machine for no more than I would use it. I guess I should say- no more than I need one. I would probably use it more often if I owned it, whereas now I only go get one when I really need it.
Urbanengineer
USA
Great businesses have failed for trying to overextend. If you increase your overhead, your price will have to increase even if you aren’t using this tool.
We are on Farm, is ALWAYS a Use for One, have used my old Allis 180 as a Fork Truck, Grader and Loader it was not intended to do. Hydraulics Tired, 2000psi on a REALLY good Day, almost could not lift the bare block C15 in and out of Pickup. Need to do more road work, have a Creek Bank in need of erosion correction, have a Drainage path to set pipe and backfill along North Fence Line where can get a MiniEx for a few days lay pipe but hill side angles and volume of Fill requires something a bit better than AG tractor. At barn Feedlot have remains of old foundation not ever got to with 7G, was always too busy fixing it. Have some Terrace heads need regrade and a number of areas just needing grade work the Allis cannot handle. need to expand Drive at House/Shop around 8'x60' and cut out some of the Corners on Drive. Eventually need to cut grade for a 40x60-40x80 New Building, get that set and would end up selling off all but 18ac where House and Shop are, sell off 60 and Barn, move all equipment to new structure on a Concrete Floor.
Nephew has around 6 Initial Acres for Brush Busting(Forward Mount Bushog), then roads to clean up as well and set drainage cuts to control erosion damage at their place. AC or Heat for Myself becoming a Must, for him saves slapped in face with brush on a tractor. He was looking to cut rough grade to situate a 20' HC Conex for Storage, possibly Two with a Roof across Gap Between. I constructed two screen for Creek Rock, he can use for the Yard area at their cabin, harvest rock from Dry Creek and transport with the old Allis and Dump Wagon I have.
I have Skid Steer head on the Allis, Have the Forks, have a Post Driver to 8" Diam. for three Point, easy enough to convert to Skid Steer and do have a Load of fence needs work.
Tyler d4c
Salix Pa
I have a 259d that i have about 45000 in it may get 8 hours a year some guys have a old car i got that!
I am surprised you don't have one already. Between gravel maintenance at your shop and satellite yard to forks for moving around all sorts of stuff I think you would find one very handy.
May even be you look around and say "how did I get by without one?".
crane operator
sw missouri
I know, its really for the bucket that I need one. I've got 4 forklifts between the shops, and there's no comparison for handiness or lifting ability, between a forklift and a skid- skids are such a pain to get in and out of.
One could make the case for getting rid of a forklift and getting a skid, but that would call into question some of my past decision making.
Ten years ago I wanted a $10,000 skid loader, and they were all $20,000. "I'm not giving $20,000 for any used skid loader, that some farmer or concrete guy has already trashed" etc etc.
Today they are the same skid loader, 10 years older, with twice as many hours on them, and they still want $20,000 for them.
So if I would have bought back then, I could have used it for 10 years for zero dollars. So who's the fool here?
MG84
Virginia
Another vote for the Kubota, SVL75-2 would probably do everything you need and no DEF. I have a SVL65-2 and it's a great machine for what I need, but a little light for heavy grading/excavating (I use the dozer for that.) Kubota's have the roomiest and easiest to get in/out cabs of any skid steer I've been on which is nice when you're working by yourself getting in and out a lot. On that same note, buy yourself a set of walk through forks.100 times easier getting in/out vs standard forks with a brick gaurd.
The Takeuchi machines would be next on my list, the TL8 would probably be a good fit for your needs. The Cat machines seem to be hit or miss, some guys love them, others have a lot of problems, probably wouldn't be at the top of my list. Bobcat wouldn't even make the list, I wouldn't own anything they've made in the past 20yrs.
MG84
Virginia
One note on skid steer vs forklift, the one big advantage that a skid steer (or other loader) has vs a forklift is reach at truck/trailer bed height. I can often load/unload a truck or trailer from one side with the skid steer which isn't possible with a forklift. Also nice for loading stuff in the back of a pickup without having to take the tailgate off.
I was thinking more of using it on the job moving things around.
We were "gifted" as set of long telehandler forks that fit the skid steer mounting plate. They were leftover on a retail job and the super said you can have them or I'm putting them in the dumpster so off to the yard they went.
Those long forks are handier than a shirt pocket for all sorts of things on the job. Great for RCP and HDPE pipe as well as moving our 8x4 job boxes around. They guys rarely take the set of forks with the short tines.
