Most of those moves are at less than10 mph, so the cold isn't too bad.... And, most of the time the trailer is "locked" into a straight trailer position. There is only a man up there when maneuvering around obstacles.I was watching a show about a heavy haul company that also built the trailers, Diamond Heavy Haul. They had a 550 HP steerable pusher on the back but what seemed odd was the operator stood up to steer and it was completely open with no weather protection. Not too good when a lot of heavy moves are in the winter when the ground is frozen.
Well, once it's on it's side, there isn't much to do until a Cat and a shovel arrive to put it on it's feet, might as well pose for some photos.They don't seem too shocked that the truck flipped on its side. That's a big log.
That's because that truck doesn't exist, it's AI.They don't seem too shocked that the truck flipped on its side.
If the carb doesn't ice up.They were the most powerful engines at the time. I read an article about them a few weeks ago.
As long as you keep the rad topped up, you’re good to go.If the carb doesn't ice up.
