First of all thanks guys for all the great info. I've been a lurker here for years.
I recently bought at CAT 2008 242B2 with the 2.2 Perkins. I got it cheap as the motor was blown with less then 1000hrs. I ordered a crate perkins and slapped it in and have a great machine.
I finally had the time to tear down the old motor (I have a lot of experience with building motors) and found a fairly serious flaw. The reason my original engine failed was due to the Pistons being installed "180*" off in the bores. The pistons have valve reliefs on one side, unfortunately the valves were on the other side... every piston had marks in the top from the valves barely hitting.
The failure sequence in my motor was the valves obviously taking a minor beating (about .015" divits in pistons) over the ~1000 hrs. Piston number one eventually gave out and lost the push rod and lifter for the ex valve. The lifter dropped, and the mains lost oil pressure. This is where the cylinder one rod seized to the crank and broke.
I wanted to pass this along mostly because I have no idea if the brand new motor I put in was the same. If I had of known I would have pulled the head off and checked/dropped the pan and rotated the pistons/rods.
![1379387_10151788355941156_24617154_n.jpg 1379387_10151788355941156_24617154_n.jpg](https://www.heavyequipmentforums.com/data/attachments/106/106224-759e1a0979bbf3b0bb6de95f78d50235.jpg)
![1381915_10151801156971156_173890300_n.jpg 1381915_10151801156971156_173890300_n.jpg](https://www.heavyequipmentforums.com/data/attachments/106/106225-869186f12262788fd8354efff423dc5f.jpg)
![1395880_10151788356201156_1756774951_n.jpg 1395880_10151788356201156_1756774951_n.jpg](https://www.heavyequipmentforums.com/data/attachments/106/106226-9ad0fac56fbcf4c15f425e0962893f7c.jpg)
