the park brake holds the machine i believe he used the shop hydraulic hand pump to release the park brake thats what i gathered this morning from him
Okay, that make more sense! That brake has adjusted just like old drum brakes on cars, a bit tricky to get to the cog wheel but can be done from front side. But if the brake drum and shoes are as nasty as the actuator looks I 'm not sure how good it could work! The burnishing in procedure for new shoes surprised me when I read it.
Note: Replacement brake shoes must be burnished. In order to burnish the brake shoes, make three successive stops from third speed forward at maximum speed. Allow the parking brake to cool to ambient temperature after the third stop.
Knowing how well that brake works at slow speeds had me hesitating to snap it on while running flat out in 3rd the first time!
And while we are talking about this parking brake, test procedure is as follows:
Note: The following step will produce a Warning Category 3. The parking brake indicator will turn ON and the master action light will flash. The action alarm will sound.
Engage the parking brake. Change upshift gear speed switch (2) to THIRD SPEED. Change transmission direction control switch (3) to the FORWARD position, while the AUTO shift switch is in the OFF position.
Gradually increase the engine speed to high idle. The machine should not move.
