980G
Machine SN: AYT249
Engine SN: BET5197
Hye all, recently we have replaced all harness for engine and transmission side due to most of them badly damaged.
Am currently facing a problem where the warning lights for hyd temp/hyd level/brake pressure/hyd filter bypass is turned ON.
We've performed the continuity test for all the sensors/switch to the monitoring ECM panel and all seems fine.
Initially, we suspected the harness in the cabin was the problem since it was not replaced, but the wires all seem to be properly connected, and all continuity test passed.
Also tested with new sensors/switch and the warnings all still ON.
Perhaps anyone here can help to point out what we're missing or have any similar experience in the past.
I have a feeling all these sensors/switch shares a twisted wire that I might've missed out.
Thanks in advance
Machine SN: AYT249
Engine SN: BET5197
Thanks in advance
