850j
Robert Rdz
Corpus
I have an 850j that keeps overheating. SN T0850JX143077, we have fixed the exhaust leak it had, changed out the thermostats, verified that the radiator is not clogged. Preformed the fan motor test and it passed. Have verified solenoids are within range, verified no exhaust in the coolant, water pump is working properly, no coolant in oil. What else I’m I missing? We are going to perform the fan speed test in the morning, and we have no way of performing the flow test on the pump. Before I order the pump just wanted to make sure I am not missing anything. Thanks in advance
Simon C
Heavy Equipment Mechanic
Is it overheating on the display or with a temperature gun taking temperatures. Could a engine oil cooler be partially plugged and causing it to get warmer. Could the transmission cooler be partially blocked and causing more heat.
Is there foam seals missing around the radiator, have you checked the temperature in versus out on the radiator hoses.
What kind of oil is in the transmission, hydraulics and engine. Is something stuck over relief and causing the heat, like a by-passing cylinder.
How hot is it on the day it is getting too hot.
Have you temperature gun checked things to see if you find something else that is hot.
Simon C
mg2361
Pennsylvania
Equipment Mechanic
Verified with a temp gun to eliminate a bad sensor? If the radiator core is clean, then a fan speed test is. Make sure the test is performed as stated in the Operation and Test manual (1450 rpm minimum with the transmission oil temp at 135*-150*F ).
Robert Rdz
Corpus
Ok we verified the sensor, fan speed was at 1600 rpms. Verified temperature in radiator and no cold spots so we are thinking that’s not clogged. Going to replace the water pump to see if that helps it. Anything else we might be missing?
ohdeereme
North Carolina
Check the radiator core again. If you had an exhaust leak the fins could have a film of soot on them that could cause the coolant to overheat. I've had a couple I could see through core and had air flow but still wouldn't cool. If that's the case you'll have to clean it with a hot water pressure washer, blowing through it with compressed air won't remove the soot.
Shimmy1
North Dakota
What was the temp at the top versus the bottom? You just say "no cold spots", that doesn't mean anything. I'm going to assume that you saw a small difference, since you didn't notice anything out of the ordinary. That could be a coolant flow issue, but it also could very well be the radiator is clogged internally or externally. You need to retest your temps, several times from soon after startup until it gets hot, and post the results.
Robert Rdz
Corpus
All we run is the John Deere coolant. I am not tracking that we mix that with water. I will read the container tomorrow.
Robert Rdz
Corpus
Good morning, so temps from top to bottom have a 15-20 degree drop. Temps from side to side are measuring the same and getting cooler as we moved down. We are replacing the water pump this morning hopefully that solves the issue.
Robert Rdz
Corpus
Ok we changed out the pump and it holds between 218-219 with heavy loads running 1.5. What is the normal temperature for this dozer supposed to be?
Simon C
That is warm but would not say it is super hot for where you live and the fact that it is an older radiator system. If a yellow light does not come on keep running it and monitor the antifreeze.
For your info a 65% antifreeze to water blend does increase boil point over 50% or less than 50% antifreeze strength. 70% is the highest allowed from what I know.
Simon C
Robert Rdz
Corpus
Good morning after changing out the water pump and filling up the coolant to the right level and running it for the last five hours the highest temperature was temperature 217 degrees with the blade fully loaded with brush. Thank you all for the advice and helpful information.
