TRAVIS HEWETT
Anyone dealt with solving the reocuring engine vibration with the 9 litre Tier III engine. This particular engine is in a 672GP. JD is wanting to put another set of engine mounts in. This will be the second set since I have been operating the grader. I recently came back to work for the agency that owns the grader. While I was gone less than 200 hours were put on the machine and it is probably been less than 500 since the first set of motor mounts were replaced for the same issue. The grader has almost 1300hrs presently. The vibration comes in at 1400rpm and smooths back out at 1700rpm. Vibration occurs in all situations whether parked, moving, no load, or grading. The first set of new mounts solved the issue when I was working with the agency but since I have been back and operating the grader the vibration has reoccured. Also having same issues since the grader was purchased with either the tensioner pulley and the one above it chirping/squeaking. They have been replace in the past also but this issue has also reoccured. Hopefully someone can give some insight on these issues. Thanks in advance for everyones help and any info.
