627E yellow metal in transmission filter
AJL
New Zealand
heavy diesel mechanic
I have a 627E, 6GB00686 serial that when I gave it a 500hr service the front transmission filter was full of yellow metal, including the oil.
I dropped the trans oil, which looked pretty clean, and check the screens and magnets. Some debris on the screens and magnets but majority of the debris was in the filter
I believe the oil path is from the differential portion of the transmission housing, through the screens, pump then filter, so I pulled the charge and scavenge pump to strip and assess. No abnormal wear found.
I made the call and pulled the transmission.
On inspection of the transmission parts, no abnormal wear is found. Another experienced mechanic suggested checking the retarder for the source of material.
Has anyone come across very fine bronze or brass looking particles in the filter before?
Zachthemechanic
Montana
When I worked on the mountain (ski resort) we switched to Schaefer lube for our snowcats and their was additives in it that at the time ate brass and bronze idk it wiped out quite a few pumps before we caught on
