580M Fan Belt Not Tracking
Bootheal
Jackson, MO
‘You guys are amazing’
Read this in a post earlier and totally agree.
Next issue: serpentine belt doesn’t stay put in the correct grooves of the fan pulley.
This was a new belt maybe couple years ago. I didn’t replace the idler but probably should have. Didn’t feel or look bad.
Thanks in advance for any ideas.
mekanik
Canada's Northwest
Looking at the pictures the gap between the tensioner lever arm and its mount looks wider at the top.
It might be the picture but that is how tensioners wear. I suspect that is your problem.
92U 3406
Western Canuckistan
Wrench Bender
Have seen the arms on tensioners twist over time.
I would start by checking and verifying that all pullies are in alignment and are square at all possible angles.
Tinkerer
usa
Get ahold of a fan blade and see you can wiggle the fan. You may have a water pump bearing on its way out.
It could be that AND the tensioner.
willie59
Knoxville TN
Service Manager
Two most commons causes as mentioned previously, 1) fan tower bearings shot causing misalignment of fan pulley, seen it more than once, and 2) worn tensioner pivot causing tensioner pulley misalignment.
Bought my last tensioner off of Amazon, think it was 30 bucks.
Pretty good unit.
Bote
Kentucky
Tensioner replacement - 15 minutes
Tensioner and belt replacement - 3 hours
A bad tensioner will destroy the belt. My Case 450C dozer has the same setup and I replaced the tensioner when it started getting slightly wiggly just because I didn't want to replace the belt.
