LINDELL CRUISE
What do I need to know to disassemble the steering cylinder so I can replace seals?
Spot on advice. Thanks. I already got that far. Now trying to take the end caps off the cylinder. LH end has 3 hollow-head bolts that take 14mm Allen wrench, RH end takes 8mm. Can't budge even with impact wrench. Looking for suggestions. The cylinder is part of the casting between the U-joint and front axle. (It's a 1989 model).
How does the gland ends break lose from the cylinder I've got the three Allen head screws out but not having any luck with the gland ends
This is from the service manual. 580k phase III. You really need to buy the manual. I can only post 4 images per post due to HEF limitations.
View attachment 193939 View attachment 193940 View attachment 193941 View attachment 193942
I'm unable to get anything to separate from housing on either side?This is from the service manual. 580k phase III. You really need to buy the manual. I can only post 4 images per post due to HEF limitations.
