tylerroy73
I have a 580 super m with a 4bt Cummins, I replaced the injection pump, now the fuel shut off is not working. I replaced it and it worked the initial crank after instal and now it’s not functioning. It’s stays closed I can turn the key on and manually open it and it will hold but it will not open while cranking.
From what I see voltage is ok I’m just at a loss and not sure where to go next.
New injection pump
New fuel shut off
No visible damage to harness.
New injection pump
New fuel shut off
